简介
Did some water sneak its way into your GoPro and fry the motherboard? This guide will walk you through how to get to the meat of your GoPro and give it new life with a motherboard!
你所需要的
Pull the tab on the back of the device to release the back cover. It should come right off.
Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
Using your trusty screwdriver, remove the single 3.2mm PH00 screw connecting the motherboard to the midframe.
18等其他人完成本指南。
1指南评论
Hello Chad,
Thanks for the very helpful and detailed guide.
Could you please tell us how you narrowed down the problem to the motherboard and not to other parts? What kind of problems were you having with your GoPro before you repaired it? After you have replaced the motherboard and put the camera back together, did you have to do anything else to make it work like reconfigure the firmware?
Appreciate your help. Thanks!
