跳转到主内容
GoPro Hero Motherboard Replacement
你所需要的
  1. GoPro Hero Motherboard Replacement, Casing: 步骤 1 中的图像 1,1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: 步骤 2 中的图像 1,1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 GoPro Hero Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: 步骤 8 中的图像 1,2 GoPro Hero Motherboard Replacement: 步骤 8 中的图像 2,2
    • Separate the white plastic piece from the motherboard.
结论
4等其他人完成本指南。
Zoe Tuggle
于04/01/15注册
179 声望
撰写一个指南
团队
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G2
4 名成员
创作了18篇指南
2条评论
So after doing all theses steps did it resolve the problem
Anita - 回复
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 41
总计 10,099
