跳转到主内容
GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement
你所需要的
  1. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Casing: 步骤 1 中的图像 1,1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 步骤 2 中的图像 1,1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 步骤 3 中的图像 1,1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 步骤 4 中的图像 1,1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 步骤 6 中的图像 1,1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: 步骤 7 中的图像 1,2 GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement, Micro USB/MicroSD Card Daughter Board: 步骤 7 中的图像 2,2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 步骤 8 中的图像 1,1
    • Remove the two screws located on each side of the board with a Phillips screwdriver.
    • The screws go through an L metal bracket that will come off with the screws.
  9. GoPro Hero Micro USB/MicroSD Card Daughter BoardReplacement: 步骤 9 中的图像 1,1
    • Separate the daughter board from the white plastic piece.
结论
5等其他人完成本指南。
River Drake
于04/02/15注册
1,035 声望
创作了5篇指南
团队
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G2
4 名成员
创作了18篇指南
4条评论
Wo kann ich ein daughterboard kaufen habt ihr da was für mich?
Lukas Blohm - 回复
bravo! è scritto molto bene ed è stato utile. ma dove trovo il ricambio? non ci riesco!!!
michele - 回复
Terrific guide. Does anyone know where to buy the “daughter board”?
fedebossert - 回复
fedebossert - 05/27/20
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 24
总计 4,783
