跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
GoPro Hero LCD Screen Replacement
你所需要的
  1. GoPro Hero LCD Screen Replacement, Casing: 步骤 1 中的图像 1,1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 1,2 GoPro Hero LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 2,2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: 步骤 10 中的图像 1,2 GoPro Hero LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Separate the LCD screen from the motherboard.
结论
5等其他人完成本指南。
River Drake
于04/02/15注册
1,023 声望
创作了5篇指南
团队
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G2
4 名成员
创作了18篇指南
3条评论
Where do you buy the replacement lcd
Anthony Volatile - 回复
I can find the screen but is it compatible with the Hero+
Brian Casado - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 71
过去 30 天: 307
总计 22,483
