跳转到主内容
GoPro Hero 4 Black USB Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. GoPro Hero 4 Black USB Replacement, Replacing USB Port: 步骤 1 中的图像 1,1
    • First, you will have to remove the faceplate by carefully using the spudger around the edge to loosen the clips.
    • After loosening the clips on the edge, pull the faceplate off.
    • Be aware that there is double-sided tape on the backside of the faceplate (indicated by the red arrow).
  2. GoPro Hero 4 Black USB Replacement: 步骤 2 中的图像 1,1
    • Now, you will need to take a PH000 Philips head screwdriver and remove the 4 corner screws.
    • Note: The screws circled in red are longer than the screw circled in orange.
  3. GoPro Hero 4 Black USB Replacement: 步骤 3 中的图像 1,1
    • Now, you will need to remove the camera and boards from the black plastic housing. You may use any tool that will do the job. My group found out, if you use the plastic tool to remove the boards and camera, that it would assist you with the removal.
  4. GoPro Hero 4 Black USB Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon strip by carefully pulling on it. It should slide out of its connection.
    • When you push down on the three wires that are connected to the clip. The clip will disconnect from the motherboard.
  5. GoPro Hero 4 Black USB Replacement: 步骤 5 中的图像 1,1
    • Take yourPH000 Philips head screwdriver to remove the four screws outlined in red.
    • Once the screws are removed. Gently remove the board and as you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
  6. GoPro Hero 4 Black USB Replacement: 步骤 6 中的图像 1,1
    • Take your PH000 Philips head screwdriver and remove the three screws that are outlined in red.
    • Just like before, gently pull up on the ribbon strip to remove the connector from the motherboard.
  7. GoPro Hero 4 Black USB Replacement: 步骤 7 中的图像 1,1
    • Remove the two screws to remove the riser that is being held in place by the screws.
  8. GoPro Hero 4 Black USB Replacement: 步骤 8 中的图像 1,1
    • Remove a single screw located near the barcode.
    • Note: Once the screw is removed, only the ribbon strip on the bottom of the motherboard is holding it.
  9. GoPro Hero 4 Black USB Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • At the top of the ribbon strip, there is a black clip that will need to be popped up.
    • Note: You can use your finger to pop the clip, but a pair of tweezers might be of help.
  10. GoPro Hero 4 Black USB Replacement: 步骤 10 中的图像 1,1
    • Gently, grab the ribbon with a pair of tweezers to disconnect the ribbon from the connecter.
    • Now, the motherboard can be removed. Due to the USB connector being soldered to the motherboard, the entire board will need to be replaced.
结论
8等其他人完成本指南。
团队
IUPUI, Team 1-2, Hagerty Fall 2015 IUPUI, Team 1-2, Hagerty Fall 2015 的会员
IUPUI-HAGERTY-F15S1G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 3,638
