你所需要的
Use the plastic opening tool to remove the faceplate.
There is some adhesive and clips so be careful and the faceplate should pop right off.
Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
You should now be able to remove the image sensor by simply pulling it.
即将完成!
结论
2等其他人完成本指南。
