跳转到主内容
加入维修社区 - 创建账户
GoPro Hero 3 Silver Expansion Port Replacement
你所需要的
  1. GoPro Hero 3 Silver Expansion Port Replacement, Battery: 步骤 1 中的图像 1,2 GoPro Hero 3 Silver Expansion Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Pull back on the tab on the back of GoPro to open the battery cover.
    询问修复机器人
    添加评论
  2. GoPro Hero 3 Silver Expansion Port Replacement: 步骤 2 中的图像 1,1
    • Pull the battery out using the tab.
    询问修复机器人
    添加评论
  3. GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: 步骤 3 中的图像 1,2 GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
    询问修复机器人
    添加评论
  4. GoPro Hero 3 Silver Expansion Port Replacement: 步骤 4 中的图像 1,2 GoPro Hero 3 Silver Expansion Port Replacement: 步骤 4 中的图像 2,2
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
    询问修复机器人
    添加评论
  5. GoPro Hero 3 Silver Expansion Port Replacement: 步骤 5 中的图像 1,2 GoPro Hero 3 Silver Expansion Port Replacement: 步骤 5 中的图像 2,2
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
    询问修复机器人
    添加评论
  6. GoPro Hero 3 Silver Expansion Port Replacement: 步骤 6 中的图像 1,2 GoPro Hero 3 Silver Expansion Port Replacement: 步骤 6 中的图像 2,2
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
    询问修复机器人
    添加评论
  7. GoPro Hero 3 Silver Expansion Port Replacement: 步骤 7 中的图像 1,3 GoPro Hero 3 Silver Expansion Port Replacement: 步骤 7 中的图像 2,3 GoPro Hero 3 Silver Expansion Port Replacement: 步骤 7 中的图像 3,3
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
    询问修复机器人
    添加评论
  8. GoPro Hero 3 Silver Expansion Port Replacement: 步骤 8 中的图像 1,2 GoPro Hero 3 Silver Expansion Port Replacement: 步骤 8 中的图像 2,2
    • The media adapter is attached to the motherboard via 3 screws:
    • x1 T4 Torx
    • x2 Phillips #00
    • There is a little silver bracket (in the yellow circle) that is held down by the Phillips #00 screw so be careful not to lose it.
    询问修复机器人
    添加评论
  9. GoPro Hero 3 Silver Expansion Port Replacement: 步骤 9 中的图像 1,2 GoPro Hero 3 Silver Expansion Port Replacement: 步骤 9 中的图像 2,2
    • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
    • Remove the media adapter from the motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Brian Alvarez
于04/02/15注册
1,439 声望
创作了6篇指南
团队
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G7
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 51
总计 2,294
