跳转到主内容
GoPro Hero 3+ Silver Edition Motherboard Replacement
你所需要的
  1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero 3+ Silver Edition Motherboard Replacement, Front Panel: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 4 中的图像 1,1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: 步骤 5 中的图像 1,3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: 步骤 5 中的图像 2,3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: 步骤 5 中的图像 3,3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 6 中的图像 1,2 GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 8 中的图像 1,2 GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 8 中的图像 2,2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  9. GoPro Hero 3+ Silver Edition Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  10. GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 10 中的图像 1,3 GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 10 中的图像 2,3 GoPro Hero 3+ Silver Edition Motherboard Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
结论
3等其他人完成本指南。
Blake Ehlers
于10/01/15注册
668 声望
创作了3篇指南
团队
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G8
4 名成员
创作了12篇指南
2指南评论
hi, where i can find the matherboard for de hero 3+ silver?
Mauricio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 3,833
