跳转到主内容
GoPro Hero+ LCD Motherboard Replacement
你所需要的
  1. GoPro Hero+ LCD Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,2 GoPro Hero+ LCD Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
  2. GoPro Hero+ LCD Motherboard Replacement: 步骤 2 中的图像 1,2 GoPro Hero+ LCD Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Motherboard Replacement: 步骤 3 中的图像 1,2 GoPro Hero+ LCD Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
  4. GoPro Hero+ LCD Motherboard Replacement, Battery: 步骤 4 中的图像 1,1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Motherboard Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Motherboard Replacement: 步骤 6 中的图像 1,2 GoPro Hero+ LCD Motherboard Replacement: 步骤 6 中的图像 2,2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
  8. GoPro Hero+ LCD Motherboard Replacement, MicroSD/Micro USB Port Assembly: 步骤 8 中的图像 1,3 GoPro Hero+ LCD Motherboard Replacement, MicroSD/Micro USB Port Assembly: 步骤 8 中的图像 2,3 GoPro Hero+ LCD Motherboard Replacement, MicroSD/Micro USB Port Assembly: 步骤 8 中的图像 3,3
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
  9. GoPro Hero+ LCD Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
  10. GoPro Hero+ LCD Motherboard Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
  11. GoPro Hero+ LCD Motherboard Replacement: 步骤 11 中的图像 1,1
    • Gently lift the microSD/Micro USB assembly up and out of the device.
  12. GoPro Hero+ LCD Motherboard Replacement, Image Sensor: 步骤 12 中的图像 1,1
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
  13. GoPro Hero+ LCD Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,3 GoPro Hero+ LCD Motherboard Replacement, Motherboard: 步骤 13 中的图像 2,3 GoPro Hero+ LCD Motherboard Replacement, Motherboard: 步骤 13 中的图像 3,3
    • Remove the three 4 mm Phillips #000 screws securing the motherboard.
  14. GoPro Hero+ LCD Motherboard Replacement: 步骤 14 中的图像 1,1
    • Use your fingers to gently remove the ribbon connected to the lens.
    • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
  15. GoPro Hero+ LCD Motherboard Replacement: 步骤 15 中的图像 1,3 GoPro Hero+ LCD Motherboard Replacement: 步骤 15 中的图像 2,3 GoPro Hero+ LCD Motherboard Replacement: 步骤 15 中的图像 3,3
    • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
结论
2等其他人完成本指南。
Matthew Tinkey
于08/27/15注册
922 声望
创作了4篇指南
团队
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G4
4 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 22
总计 5,039
