跳转到主内容
加入维修社区 - 创建账户
GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement
你所需要的
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: 步骤 1 中的图像 1,2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: 步骤 1 中的图像 2,2
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      添加评论
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 2 中的图像 1,2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 2 中的图像 2,2
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      询问修复机器人
      添加评论
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 3 中的图像 1,2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 3 中的图像 2,2
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      添加评论
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Battery: 步骤 4 中的图像 1,1
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      询问修复机器人
      添加评论
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers, peel off the copper tape on the right side of the battery.
      询问修复机器人
      添加评论
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 6 中的图像 1,2 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 6 中的图像 2,2
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      询问修复机器人
      添加评论
    4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 7 中的图像 1,1
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      添加评论
    1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: 步骤 8 中的图像 1,3 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: 步骤 8 中的图像 2,3 GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: 步骤 8 中的图像 3,3
      • Remove the two 6 mm Phillips #00 screws.
      • Remove the single 4 mm Phillips #000 screws.
      询问修复机器人
      添加评论
    2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 9 中的图像 1,1
      • Remove the image sensor from the camera.
      • You do not have to unplug the black box to remove the USB/SD chip.
      询问修复机器人
      添加评论
    3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 10 中的图像 1,1
      在这个步骤中使用的工具:
      • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
      • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
      询问修复机器人
      添加评论
    4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: 步骤 11 中的图像 1,1
      • Gently lift the microSD/Micro USB assembly up and out of the device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G4
4 名成员
创作了20篇指南
2指南评论
Hi were can i buy the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Hector - 回复 分享
Very helpful guide
Ninigo Marine Contractor - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 42
总计 4,260
