跳转到主内容
加入维修社区 - 创建账户
GoPro Hero+ LCD Battery Replacement
你所需要的
    1. GoPro Hero+ LCD Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 GoPro Hero+ LCD Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      添加评论
    2. GoPro Hero+ LCD Battery Replacement: 步骤 2 中的图像 1,2 GoPro Hero+ LCD Battery Replacement: 步骤 2 中的图像 2,2
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      询问修复机器人
      添加评论
    3. GoPro Hero+ LCD Battery Replacement: 步骤 3 中的图像 1,2 GoPro Hero+ LCD Battery Replacement: 步骤 3 中的图像 2,2
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      添加评论
    1. GoPro Hero+ LCD Battery Replacement, Battery: 步骤 4 中的图像 1,1
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      询问修复机器人
      添加评论
    2. GoPro Hero+ LCD Battery Replacement: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • Using tweezers, peel off the copper tape on the right side of the battery.
      询问修复机器人
      添加评论
    3. GoPro Hero+ LCD Battery Replacement: 步骤 6 中的图像 1,2 GoPro Hero+ LCD Battery Replacement: 步骤 6 中的图像 2,2
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      询问修复机器人
      添加评论
    4. GoPro Hero+ LCD Battery Replacement: 步骤 7 中的图像 1,1
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      添加评论
结论
取消:我没有完成这个指南。
19等其他人完成本指南。
Kyle
于08/27/15注册
219 声望
撰写一个指南
团队
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G4
4 名成员
创作了20篇指南
13指南评论
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - 回复 分享
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård - 回复 分享
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - 回复 分享
not even amazon?
Mary D'Alesandro - 回复 分享
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 36
过去 30 天: 202
总计 42,490
