跳转到主内容
GoCube Unchargeable Battery Fix
你所需要的
  1. GoCube Unchargeable Battery Fix, Create a hole in the inner sphere: 步骤 2 中的图像 1,1
    • Using a drill or dremel, create a hole in the inner sphere between the red and white center pieces.
    • Go slow and make sure you don't go too deep or you might hit the battery or something else inside.
  2. GoCube Unchargeable Battery Fix, Get a power source: 步骤 3 中的图像 1,1
    • You need at least 5 volts. This shows 4 AA batteries together in series. There's a wire connecting the ends on the right. The ends on the left each have a wire coming out. I used copper wire, but metal paper clips would probably be easier to adjust in the next step.
  3. GoCube Unchargeable Battery Fix, Jump start the battery: 步骤 4 中的图像 1,1
    • Hold the wire coming from the battery positive terminal to the red solder pad and the negative battery terminal to the black solder pad.
    • Hold it in place for a few seconds. I think I did it while the charger was connected. Not sure if you have to do it that way.
    • Plug the charger back into the cube if it's not already, connect the cube to the GoCube app, and let it charge for a minute.
    • Try removing the cube from the charger and see if it disconnects. If it still disconnections, keep trying. It took me a few tries before it finally worked.
    • Placing the battery wires in the wrong place could break your cube, but it's already unusable since you can't take if off the charger, so not like it will make it worse.
结论
Now just never let it die again, or you'll probably have to do this again. And never buy anything from GoCube again since they're terrible.
Credit for the fix to David García Illanas at https://www.kickstarter.com/projects/192...
2等其他人完成本指南。
Dave L
于08/20/20注册
181 声望
撰写一个指南
6指南评论
Sir. Bless you may you live long and prosper.
rpitcher517 - 回复
If this works, I wonder if it might be possible to accomplish the same thing by just sending some excess voltage through the regular charging cable. I might try it out with my useless cube before putting a hole in it.
Todd Corson - 回复
Any luck with the higher voltage through the regular charging ports?
Andrew Makowski -
Thank you for the tips. I have 2. Both dead. One was a replacement for one that was dead in the box. Can't understand was this wasn't a design consideration. I hope they resolved this issue on newer models.
ryan harrison - 回复
Hello, I tried this method but unfortunately the battery wont charge. Although when I plug the external DIY battery I can connect to the cube and it seems to work well (Enable / disable led and gyro tracking from the app works.
The cube is not dead only the battery is. So I removed it. Now I'm searching for a replacement. Did you guys know where I can find some ?
Maybe solder a connector like those those and print some 3D support for not rechargeable button battery i will have to change regularly...
More ideas are welcome.
Florian BEAULIEU - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 74
总计 5,231
