跳转到主内容
加入维修社区 - 创建账户
Glass Door Latch Replacement
你所需要的
  1. Glass Door Latch Replacement, Outer Removal: 步骤 1 中的图像 1,3 Glass Door Latch Replacement, Outer Removal: 步骤 1 中的图像 2,3 Glass Door Latch Replacement, Outer Removal: 步骤 1 中的图像 3,3
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: 步骤 2 中的图像 1,3 Glass Door Latch Replacement, Preparation: 步骤 2 中的图像 2,3 Glass Door Latch Replacement, Preparation: 步骤 2 中的图像 3,3
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: 步骤 3 中的图像 1,2 Glass Door Latch Replacement: 步骤 3 中的图像 2,2
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: 步骤 4 中的图像 1,2 Glass Door Latch Replacement, Mechanism Removal: 步骤 4 中的图像 2,2
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: 步骤 5 中的图像 1,2 Glass Door Latch Replacement, Replacement Prep: 步骤 5 中的图像 2,2
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: 步骤 6 中的图像 1,3 Glass Door Latch Replacement, Installation: 步骤 6 中的图像 2,3 Glass Door Latch Replacement, Installation: 步骤 6 中的图像 3,3
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: 步骤 7 中的图像 1,3 Glass Door Latch Replacement, Installation Cont.: 步骤 7 中的图像 2,3 Glass Door Latch Replacement, Installation Cont.: 步骤 7 中的图像 3,3
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: 步骤 8 中的图像 1,2 Glass Door Latch Replacement, Latch Correction: 步骤 8 中的图像 2,2
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: 步骤 9 中的图像 1,3 Glass Door Latch Replacement, Handle Placement: 步骤 9 中的图像 2,3 Glass Door Latch Replacement, Handle Placement: 步骤 9 中的图像 3,3
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
结论
另外一个人完成了本指南。
CJ Cummings
于05/04/20注册
193 声望
撰写一个指南
3指南评论
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - 回复 分享
what brand or manufacturer is this door/lock assembly. im trying to find keyed trim for this
yaakov danzig - 回复 分享
Thank you so much for this post. I was a little nervous about replacing my sliding door lock. Your step by step instructions with pictures made the replacement of my lock so easy.
Dawn - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 99
总计 8,651
