跳转到主内容
Gigabyte RTX 3060 GPU Fan Replacement
你所需要的
  1. Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: 步骤 1 中的图像 1,3 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: 步骤 1 中的图像 2,3 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: 步骤 1 中的图像 3,3
    • Remove the four springs screws attached to the thermal plate on the GPU using a Phillips #00 screwdriver.
    • Remove the two screws from the right side using a Phillips #00 screwdriver.
    • Remove the two screws from the left side using a Phillips #00 screwdriver.
  2. Gigabyte RTX 3060 GPU Fan Replacement: 步骤 2 中的图像 1,3 Gigabyte RTX 3060 GPU Fan Replacement: 步骤 2 中的图像 2,3 Gigabyte RTX 3060 GPU Fan Replacement: 步骤 2 中的图像 3,3
    • Lift the backplate off after the screws are removed.
    • You will notice both sides of the card have a cable holding the cover and the main GPU board.
    • Carefully remove the connector at the top of the GPU (the side with GEFORCE RTX like on the picture) connecting the GPU board and the fan cover.
  3. Gigabyte RTX 3060 GPU Fan Replacement: 步骤 3 中的图像 1,2 Gigabyte RTX 3060 GPU Fan Replacement: 步骤 3 中的图像 2,2
    • Flip over the GPU cover.
    • Remove the four screws using a Phillips #00 screwdriver.
  4. Gigabyte RTX 3060 GPU Fan Replacement: 步骤 4 中的图像 1,2 Gigabyte RTX 3060 GPU Fan Replacement: 步骤 4 中的图像 2,2
    • Set the thermal system to the side.
    • Flip over the GPU cover with the fans and find the fan that needs to be replaced.
    • There are three screws underneath the fan blades. Look at the second picture as a reference for one of the screws. Remove all three using a Phillips #00 screwdriver.
  5. Gigabyte RTX 3060 GPU Fan Replacement: 步骤 5 中的图像 1,2 Gigabyte RTX 3060 GPU Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the connector associated with the fan.
    • Pull the fan out with its connector cable intact.
  6. Gigabyte RTX 3060 GPU Fan Replacement: 步骤 6 中的图像 1,1
    • Grab your replacement fan for the Gigabyte RTX 3060.
    • The repair can be completed with the replacement fan by reversing the steps previously shown.
结论
sanskar1016
于10/25/23注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 4-22, Kershman Fall 2023 CSU Los Angeles, Team 4-22, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G22
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 54
过去 30 天: 229
总计 1,420
