跳转到主内容
Gigabyte P34G Speakers Replacement
你所需要的
  1. Gigabyte P34G Speakers Replacement, Speakers: 步骤 1 中的图像 1,1
    • Remove all 15 marked screws on the underside of the laptop using a Phillips #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
  2. Gigabyte P34G Speakers Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 4 marked 4.5mm screws using a Phillips #0 screwdriver.
    • Save the screws in a safe place for reassembly later.
  3. Gigabyte P34G Speakers Replacement: 步骤 3 中的图像 1,1
    • Unplug the connector by pulling on the wires.
  4. Gigabyte P34G Speakers Replacement: 步骤 4 中的图像 1,1
    • Grab the speakers and pull for removal.
结论
yeunghayden
于05/01/15注册
841 声望
创作了6篇指南
团队
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G1
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 798
