简介
This guide will walk through the process of adjusting the hydraulic breaks on a bicycle by means of adding hydraulic fluid to the system. Properly done, this process will increase the responsiveness of your brakes, shortening the amount of time required to bring your bicycle to a stop.
你所需要的
Pull out and rotate the quick release lever until the axle is loose.
Pull back on the derailleur on the left hand side. This lessens the force required to remove the wheel from its mount greatly.
Lift the bike, and pull the wheel from its mount.
To reassemble your device, Replace the cover on the hydraulic port and reinstall the wheel with the calipers still in their widened position. Make sure that all screws over on the hydraulic ports are very secure. Once the wheel is installed, pump the brakes a few times to seat the brake pads. Confirm function of your brakes before attempting to ride the bike by inverting the bike so that it rests on the handlebars and seat, then spinning the rear and front wheels manually. If this does not work, you may need to add more fluid. Ride safe!
另外一个人完成了本指南。
