本指南有最近更改,您可查看未经巡查的最新版本。
简介
Removing the front wheel of the Giant Reign 2 is a common first step for other repair guides. This guide will clearly show you how to use simple tools to remove the front wheel quickly and safely.
你所需要的
Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
Push the axle screw to reveal the axle rod on the other side.
2等其他人完成本指南。
