跳转到主内容
Giant Reign 2 Front Wheel Replacement
你所需要的
  1. Giant Reign 2 Front Wheel Replacement, Hex Screws: 步骤 1 中的图像 1,1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Front Wheel Replacement, Axle Screw: 步骤 2 中的图像 1,2 Giant Reign 2 Front Wheel Replacement, Axle Screw: 步骤 2 中的图像 2,2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Front Wheel Replacement: 步骤 3 中的图像 1,1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Front Wheel Replacement, Front Wheel: 步骤 4 中的图像 1,1
    • Pull the wheel from the fork.
结论
2等其他人完成本指南。
Andrew Krasts
于10/05/12注册
302 声望
创作了2篇指南
团队
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G14
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 36
过去 30 天: 144
总计 11,423
