跳转到主内容
Ghost Longboard Wheel Replacement
你所需要的
  1. Ghost Longboard Wheel Replacement, Wheel: 步骤 1 中的图像 1,1
    • Using a 15 mm socket wrench, unscrew the axle nut.
  2. Ghost Longboard Wheel Replacement: 步骤 2 中的图像 1,1
    • Using your fingers, remove the axle nut from the axle.
  3. Ghost Longboard Wheel Replacement: 步骤 3 中的图像 1,1
    • Remove the washer from the axle.
  4. Ghost Longboard Wheel Replacement: 步骤 4 中的图像 1,1
    • Remove the wheel from the axle.
  5. Ghost Longboard Wheel Replacement: 步骤 5 中的图像 1,1
    • Remove the second washer from the axle.
  6. Ghost Longboard Wheel Replacement: 步骤 6 中的图像 1,1
    • Slide a new washer onto the axle.
  7. Ghost Longboard Wheel Replacement: 步骤 7 中的图像 1,2 Ghost Longboard Wheel Replacement: 步骤 7 中的图像 2,2
    • Place the new wheel on the axle.
    • Be sure to position the flat side of the wheel so it is facing inward.
  8. Ghost Longboard Wheel Replacement: 步骤 8 中的图像 1,1
    • Place a second washer on the axle exterior to the wheel.
  9. Ghost Longboard Wheel Replacement: 步骤 9 中的图像 1,1
    • Place an axle nut on the axle.
  10. Ghost Longboard Wheel Replacement: 步骤 10 中的图像 1,1
    • Using a 15 mm socket wrench, tighten the axle nut.
    • Be sure to tighten the axle nut enough to prevent the wheel from wobbling, but not so tight as to prohibit the wheel from spinning freely.
结论
Repeat these steps on the three remaining wheels.
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 386
