跳转到主内容
Genesis II CSS-315 Ignitor Replacement
你所需要的
  1. Genesis II CSS-315 Ignitor Replacement, Ignitor: 步骤 1 中的图像 1,2 Genesis II CSS-315 Ignitor Replacement, Ignitor: 步骤 1 中的图像 2,2
    • Be sure the grill is turned off before beginning this guide.
    • Remove all of the control knobs.
    • The amount of knobs may vary depending on the grill.
  2. Genesis II CSS-315 Ignitor Replacement: 步骤 2 中的图像 1,2 Genesis II CSS-315 Ignitor Replacement: 步骤 2 中的图像 2,2
    • Remove the two 19 mm screws below the control knob panel using a Phillips #3 screwdriver.
  3. Genesis II CSS-315 Ignitor Replacement: 步骤 3 中的图像 1,2 Genesis II CSS-315 Ignitor Replacement: 步骤 3 中的图像 2,2
    • Push up on the front panel, and pull it up above the grill.
    • Potential for device damage: The ignitor is connected to the front panel, so do not pull too hard.
  4. Genesis II CSS-315 Ignitor Replacement: 步骤 4 中的图像 1,2 Genesis II CSS-315 Ignitor Replacement: 步骤 4 中的图像 2,2
    • Disconnect the cables from the ignitor.
  5. Genesis II CSS-315 Ignitor Replacement: 步骤 5 中的图像 1,1
    • Pinch the two ends of the ignitor and remove the ignitor from the front panel.
  6. Genesis II CSS-315 Ignitor Replacement: 步骤 6 中的图像 1,1
    • Have the new ignitor on hand, and make sure that the clips on the side are in good condition.
    • Ensure that the pins at the end are straight and not bent.
  7. Genesis II CSS-315 Ignitor Replacement: 步骤 7 中的图像 1,3 Genesis II CSS-315 Ignitor Replacement: 步骤 7 中的图像 2,3 Genesis II CSS-315 Ignitor Replacement: 步骤 7 中的图像 3,3
    • Put the new ignitor into the socket.
    • Press down evenly until it is secure.
  8. Genesis II CSS-315 Ignitor Replacement: 步骤 8 中的图像 1,1
    • Connect the white cables to the ignitor.
  9. Genesis II CSS-315 Ignitor Replacement: 步骤 9 中的图像 1,2 Genesis II CSS-315 Ignitor Replacement: 步骤 9 中的图像 2,2
    • Make sure any and all cables are separated from the fire box (the bottom of the grill).
    • Slot the panel back on the grill and then push downward.
    • The fire box is the part of the grill that gets really hot, and this can damage the cables.
  10. Genesis II CSS-315 Ignitor Replacement: 步骤 10 中的图像 1,1
    • Make sure the holes match and reinsert the screws from Step 2 using a Phillips #3 screwdriver.
    • If the holes do not match up, you may have to gently push or pull the front plastic panel.
  11. Genesis II CSS-315 Ignitor Replacement: 步骤 11 中的图像 1,2 Genesis II CSS-315 Ignitor Replacement: 步骤 11 中的图像 2,2
    • Add the control knobs, and slot them into place.
终点
另外一个人完成了本指南。
Carlos Castro Paguaga
于01/18/21注册
253 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 25
总计 892
