简介
Use this guide to replace the lower feed roller bearing in a General Pipe Cleaners Drain Cleaner PMEBO 2016. There are two lower feed roller bearings—this guide only shows removal of only one of them. To remove the other, follow this procedure for the other side.
你所需要的
Use a 1/4 inch socket wrench to remove the three bolts securing the cable adjustment plate.
另外一个人完成了本指南。
一条评论
If you feel that simply opening/cleaning the drain will suffice, that's your choice. If you really want to make sure your drain is cleaned and cleared of all debris, you may want to spend a little extra for thorough results. Better care. Better value. Better results. Call a plumber drain at Curtis Plumbing FL today to avoid major problems in the future.
