跳转到主内容
General Equipment Augers M330H 2012 Throttle Cable Replacement
你所需要的
  1. General Equipment Augers M330H 2012 Throttle Cable Replacement, Remove the Cable end at the Throttle Plate.: 步骤 1 中的图像 1,1
    • Loosen the cable clamp screw, and the cable adjusting screw. You will want to hold the swivel with a wrench, or pliers when loosening the cable adjusting screw.
  2. General Equipment Augers M330H 2012 Throttle Cable Replacement, Remove cover plate: 步骤 2 中的图像 1,1
    • Slide the boot off of the throttle cable end. Remove the cover plate screw, and remove the cover plate by lifting or gently prying at the arrow
  3. General Equipment Augers M330H 2012 Throttle Cable Replacement, Remove cable end from throttle control.: 步骤 3 中的图像 1,1
    • pull out on the sheath to remove it from the housing. Lift up on the cable to release the ball from the groove. Remove the boot from the old cable to be reinstalled on the new cable.
  4. General Equipment Augers M330H 2012 Throttle Cable Replacement, Remove clamp and pull cable through the guide.: 步骤 4 中的图像 1,1
    • Use a 1/2" wrench or socket to remove the nut from the clamp. slide the cable through the guide in the direction indicated. open the clamp and remove from the old cable to be installed on the new cable.
结论
To reassemble your device, follow these instructions in reverse order. Place the boot on the new cable after putting the cable through the guide sleeve. Re-install the clamp in the middle of the cable last, once you have both ends secured.
5等其他人完成本指南。
DAVID
于07/24/20注册
230 声望
撰写一个指南
团队
The Home Depot The Home Depot 的会员
Community
13,375 名成员
创作了43篇指南
2条评论
what’s the guard piece that holds the throttle cable and next to the carburetor called?
KEVIN - 回复
I just called it the Throttle Plate. The Honda GXV160 parts page refers to the whole mess as the “primary control assembly”, and the cover over the outside as the “control protector”.
DAVID -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,038
