跳转到主内容
General Electric Create Jason Wu Casing Disassembly
你所需要的
  1. General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 1,3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 2,3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 3,3
    • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
    • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
    • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
  2. General Electric Create Jason Wu Casing Disassembly: 步骤 2 中的图像 1,2 General Electric Create Jason Wu Casing Disassembly: 步骤 2 中的图像 2,2
    • After the screws are removed, pull the front casing up and away from the camera.
    • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
  3. General Electric Create Jason Wu Casing Disassembly: 步骤 3 中的图像 1,3 General Electric Create Jason Wu Casing Disassembly: 步骤 3 中的图像 2,3 General Electric Create Jason Wu Casing Disassembly: 步骤 3 中的图像 3,3
    • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
    • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
  4. General Electric Create Jason Wu Casing Disassembly: 步骤 4 中的图像 1,3 General Electric Create Jason Wu Casing Disassembly: 步骤 4 中的图像 2,3 General Electric Create Jason Wu Casing Disassembly: 步骤 4 中的图像 3,3
    • The last part of the casing to disconnect is the back that houses the LCD screen.
    • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
    • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
    • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 369
