当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Unplug the toaster from the electrical outlet.
Remove the two levers and four dials by pulling them out directly towards you.
Removing these components may require some force, but they will release.
Look for the plastic clips on the back side of the toaster.
Disconnect the small plastic clips on the back of the toaster. Use Philips head Screwdriver to do this step.
Now, carefully remove the toaster casing.
Flip the toaster over so that the bottom plate is facing up.
Remove the four screws from the bottom of the toaster.
Carefully separate the bottom plate from the metal components inside the toaster.
Using wire cutters, cut the power supply cable close to the base of the toaster, leave about 2 inches of wire.
Pull the power supply cord through the bottom plate of the toaster.
Insert the end of the new power supply cable through the hole in the bottom plate.
Strip about an inch of the wire insulation (casing) off the ends of both the new power supply cable, and the old power supply cable that is still attached to the toaster.
Splice the stripped ends of wire together using a wire cap.
取消:我没有完成这个指南。
与8其他贡献者
于10/16/13注册
307 声望
创作了3篇指南
徽章: 7
+ 4更多徽章
UMASSD-VIJAYBHASKAR-F13S4G4
3 名成员
创作了4篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 484
