跳转到主内容
加入维修社区 - 创建账户
General Disassembly LG VX8560
你所需要的
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: 步骤 1 中的图像 1,1
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: 步骤 2 中的图像 1,1
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: 步骤 3 中的图像 1,1
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: 步骤 4 中的图像 1,1
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: 步骤 5 中的图像 1,2 General Disassembly LG VX8560: 步骤 5 中的图像 2,2
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: 步骤 6 中的图像 1,1
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
结论
另外一个人完成了本指南。
Jack Foley
于04/25/13注册
37 声望
创作了3篇指南
团队
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G62
4 名成员
创作了12篇指南
1指南评论
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 591
