简介
If your screen is cracked or non-responsive, use this guide to replace the screen.
配件
没有特定配件。
Insert the plastic opening tool into the seam between the front of the device and the rear cover.
Slide the plastic opening tool from the bottom of the phone to the top.
Use the plastic opening tool to free all the clips attached to the phone.
Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
Remove the wire from the bottom left of the motherboard by lifting it away from the device.
Remove the 2mm T3 screw in the upper left corner of the motherboard.
Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
Unfasten the plastic clamps attached to the antenna.
