当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
即将完成!
终点
另外一个人完成了本指南。
4条评论
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
