当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Insert the plastic opening tool into the seam between the front of the device and the rear cover.
Slide the plastic opening tool from the bottom of the phone to the top.
Use the plastic opening tool to free all the clips attached to the phone.
Lift the cover away from the phone.
Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
Lift the battery with the plastic opening tool and finish removing battery by hand.
Remove the two 5mm T4 screws on the sides of the small orange plate.
Gently remove the small orange plate by pulling it down.
Remove the following screws securing the back plate to the device:
Two silver 2mm T3 screws
Five black 3mm T3 screws
Slightly lift up the bottom corner of the backplate.
Release the four clips on both sides by pulling them away from the device.
Lift the backplate away from the device.
取消:我没有完成这个指南。
与4其他贡献者
于08/26/15注册
325 声望
创作了3篇指南
徽章: 11
+ 8更多徽章
USFT-EYESTONE-F15S3G5
4 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 125
