跳转到主内容
Geardup RC Ford Mustang GT Remote Circuit Board Replacement
你所需要的
  1. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 步骤 1 中的图像 1,3 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 步骤 1 中的图像 2,3 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Lower Remote Control: 步骤 1 中的图像 3,3
    • Remove the 5mm Phillips #0 screw from the remote control.
    • Using the tab, lift the battery cover from the remote control to expose the battery.
  2. Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: 步骤 2 中的图像 1,2 Geardup RC Ford Mustang GT Remote Circuit Board Replacement, Remote Circuit Board: 步骤 2 中的图像 2,2
    • Unscrew the six 5mm Phillips #0 screws on the back of the remote
    • Separate the back of the remote from the front panel.
    • During re-assembly, make sure the plastic button covers on the front panel align with the buttons on the back panel. If they do not, the buttons may be forced into an always "pressed" state.
  3. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Remove the two left and right buttons from their insets in the controller.
  4. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Remove the 5mm Phillips #0 screw that connects the antennae to the circuit board.
  5. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Unscrew 5mm Phillips #0 screw located at the bottom of the board in the center.
    • Remove the circuit board from the casing.
  6. Geardup RC Ford Mustang GT Remote Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Make note of where each wire connects to the circuit board for re-assembly as they will be removed in the next step.
    • Using the copper solder wick, remove the solder connecting the nine wires to the circuit board.
结论
7等其他人完成本指南。
Jake Stone
于02/01/15注册
611 声望
创作了4篇指南
团队
Cal Poly, Team 8-38, Amido Winter 2015 Cal Poly, Team 8-38, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G38
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 5,953
