跳转到主内容
Geardup RC Ford Mustang GT Motor Replacement Guide
你所需要的
  1. Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 步骤 1 中的图像 1,3 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 步骤 1 中的图像 2,3 Geardup RC Ford Mustang GT Motor Replacement Guide, Battery Cover: 步骤 1 中的图像 3,3
    • Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
    • Gently lift the battery cover from the car to expose the batteries.
  2. Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: 步骤 2 中的图像 1,2 Geardup RC Ford Mustang GT Motor Replacement Guide, Lower RC Car: 步骤 2 中的图像 2,2
    • Flip the car over and remove the four 5mm Phillips #0 screws that hold the shell to the car chassis.
  3. Geardup RC Ford Mustang GT Motor Replacement Guide, Shell: 步骤 3 中的图像 1,1
    • Flip the car over again to its upright position and vertically lift the shell from the car.
    • During re-assembly, make sure the shell is correctly aligned. If it is not aligned correctly, it may rub on the wheels, possibly preventing them from turning.
  4. Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: 步骤 4 中的图像 1,2 Geardup RC Ford Mustang GT Motor Replacement Guide, Rear Wheels: 步骤 4 中的图像 2,2
    • Unscrew and remove the 5mm Phillips #0 screw located at the center of the wheel while holding the wheel still.
    • Slide the wheel off of the axle.
    • Repeat the previous steps for the other rear wheel.
  5. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: 步骤 5 中的图像 1,2 Geardup RC Ford Mustang GT Motor Replacement Guide, Motor/Circuit Board Enclosure: 步骤 5 中的图像 2,2
    • Remove the eight 5mm Phillips #0 screws located on the top of the motor/circuit board enclosure.
    • Vertically lift the motor/circuit board enclosure from the car chassis.
  6. Geardup RC Ford Mustang GT Motor Replacement Guide: 步骤 6 中的图像 1,2 Geardup RC Ford Mustang GT Motor Replacement Guide: 步骤 6 中的图像 2,2
    • Using a small plastic opening tool, gently pry the clips to release the tabs on the circuit board casing. The clips can be located above where the rear wheels used to be.
    • Lift the clips just enough to release them from the tabs. If they are pried too far, they may snap off.
    • There is a clear gear grease inside the enclosure.
  7. Geardup RC Ford Mustang GT Motor Replacement Guide: 步骤 7 中的图像 1,2 Geardup RC Ford Mustang GT Motor Replacement Guide: 步骤 7 中的图像 2,2
    • Lift the circuit board casing from the enclosure to reveal the motors, gears, and circuit board.
    • During re-assembly, make sure the wires are not pinched between plastic dividers in the enclosure as this may damage them.
  8. Geardup RC Ford Mustang GT Motor Replacement Guide, Motor: 步骤 8 中的图像 1,1
    • Using the copper solder wick, remove the solder from the two wires at the points where they connect to the motor.
结论
另外一个人完成了本指南。
Matthew Seno
于02/01/15注册
191 声望
撰写一个指南
团队
Cal Poly, Team 8-38, Amido Winter 2015 Cal Poly, Team 8-38, Amido Winter 2015 的会员
CPSU-AMIDO-W15S8G38
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 358
