跳转到主内容
Gateway Solo 1200 RAM Replacement
你所需要的
  1. Gateway Solo 1200  RAM Replacement, Battery: 步骤 1 中的图像 1,3 Gateway Solo 1200  RAM Replacement, Battery: 步骤 1 中的图像 2,3 Gateway Solo 1200  RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200  RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • Locate the RAM compartment on the underside of the laptop near the center.
  3. Gateway Solo 1200  RAM Replacement: 步骤 3 中的图像 1,2 Gateway Solo 1200  RAM Replacement: 步骤 3 中的图像 2,2
    • Open the RAM compartment by unscrewing the 2 mm screw with a Phillips #0 screwdriver.
    • Once unscrewed, lift off the compartment cover.
  4. Gateway Solo 1200  RAM Replacement: 步骤 4 中的图像 1,1
    • Press the silver retention levers on either side of the RAM away from the center of the RAM.
    • The RAM stick will pop up after the retention levers are released.
  5. Gateway Solo 1200  RAM Replacement: 步骤 5 中的图像 1,1
    • Pull the RAM stick out of its socket.
结论
5等其他人完成本指南。
Addison
于08/30/19注册
3,081 声望
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 939
