跳转到主内容
修复你的物品
维修的权力
商店
简介
Procedure for dissembling the outer casing of the laptop safely.
配件
没有特定配件。
  1. Move the latch to the right of the battery to unlock.
    • Move the latch to the right of the battery to unlock.
  2. Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Unscrew the marked 5.9 mm Philips screw.
    • Unscrew the marked 5.9 mm Philips screw.
  4. Use the spudger to pry out the Disk dive.
    • Use the spudger to pry out the Disk dive.
  5. The disk drive should easily detach and can now be replaced.
    • The disk drive should easily detach and can now be replaced.
  6. Remove the twelve 5.9 mm Philips screws from the back cover.
    • Remove the twelve 5.9 mm Philips screws from the back cover.
    • Remove one 8.8 mm Philips screw from the back cover.
  7. Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery. Unscrew the three 3.6 mm Philips screws that are within the Disk drive port. Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
    • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
    • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
  8. Remove the hinge covers by lifting each with the sharp point of the spudger. Notice that the middle cover has a different shape and is more difficult to remove.
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
  9. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  10. There will be a connection underneath the speaker cover. Remove the speaker cover using the spudger. Remove the speaker cover using the spudger.
    • There will be a connection underneath the speaker cover.
    • Remove the speaker cover using the spudger.
  11. Unscrew the two 3.9 mm Philips screws and remove the keyboard.
    • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
  12. Carefully lift the keyboard off from the laptop. It is still attached as shown. Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away. The brown colored component with the tabs does not come out with the connector.
    • Carefully lift the keyboard off from the laptop. It is still attached as shown.
    • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
    • The brown colored component with the tabs does not come out with the connector.
  13. Lift up the black tab and gently pull out the connector. Lift up the black tab and gently pull out the connector. Lift up the black tab and gently pull out the connector.
    • Lift up the black tab and gently pull out the connector.
  14. Unscrew the four marked 5.9 mm Philips screws. Unscrew the four marked 5.9 mm Philips screws.
    • Unscrew the four marked 5.9 mm Philips screws.
  15. Move the wires out of the fixed space as shown. Move the wires out of the fixed space as shown.
    • Move the wires out of the fixed space as shown.
  16. Unscrew the five marked 3.8 mm Philips screws. Three screws are located on the right side of the screen.
    • Unscrew the five marked 3.8 mm Philips screws.
    • Three screws are located on the right side of the screen.
    • Two screws are located on the left side of the screen.
  17. Remove the screen brackets from the computer's base.
    • Remove the screen brackets from the computer's base.
  18. Remove the four 5.9 mm Philips screws as indicated: There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo. There are two similarly positioned screws on the right side.
    • Remove the four 5.9 mm Philips screws as indicated:
    • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
    • There are two similarly positioned screws on the right side.
  19. The following steps (18 - 20) explain how to remove the three indicated connections. The order is Blue, Violet, Orange.
    • The following steps (18 - 20) explain how to remove the three indicated connections.
    • The order is Blue, Violet, Orange.
    • Lift the white tab up and gently take out the connector.
  20. Use the spudger to pull off the black attachment.
    • Use the spudger to pull off the black attachment.
  21. Lift and pull the black tab upward until it becomes unattached.
    • Lift and pull the black tab upward until it becomes unattached.
    • Some force may be required.
  22. Use the spudger to remove the casing as seen in the picture.
    • Use the spudger to remove the casing as seen in the picture.
  23. Remove the casing.
    • Remove the casing.
结论
6等其他人完成本指南。
Diego Carteno
于2010年04月15日注册
258 信誉积分
创作了7篇指南
团队
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G20
4 名成员
创作了14篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 15,592
