跳转到主内容
Gateway SA1 Hard Drive Replacement
你所需要的
  1. Gateway SA1 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Before you begin, it's recommended that you back up all your computer's information on the original hard drive. Also, verify the laptop is off and all cables are disconnected.
    • Turn the laptop over so the bottom is facing up.
  4. Gateway SA1 Hard Drive Replacement: 步骤 4 中的图像 1,2 Gateway SA1 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Loosen the three Philips cover screws that secure the hard drive.
    • These screws cannot be fully removed from the hard drive cover.
    • Use the spudger to lift and to remove the hard drive cover.
  5. Gateway SA1 Hard Drive Replacement: 步骤 5 中的图像 1,2 Gateway SA1 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Slide the original hard drive to the left and lift it to remove.
    • Insert the new hard drive.
结论
5等其他人完成本指南。
Diego Carteno
于04/15/10注册
273 声望
创作了7篇指南
团队
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G20
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 14,193
