跳转到主内容
Gateway SA1 Cooling Fan Replacement
你所需要的
  1. Gateway SA1 Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Move the latch to the right of the battery to unlock.
  2. Gateway SA1 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
  3. Gateway SA1 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,2 Gateway SA1 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 2,2
    • Unscrew the indicated Philips screw.
    • Screw cannot be completely removed from cover.
  4. Gateway SA1 Cooling Fan Replacement: 步骤 4 中的图像 1,1
    • Use the spudger to pry open the cover.
    • There will be three tabs on each side except for the side with the screw.
  5. Gateway SA1 Cooling Fan Replacement: 步骤 5 中的图像 1,2 Gateway SA1 Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Unscrew the six indicated Philips screws.
    • These screws cannot be completely removed from the cooling fan component.
  6. Gateway SA1 Cooling Fan Replacement: 步骤 6 中的图像 1,1
    • Unplug the shown cable attaching the cooling fan to the computer.
  7. Gateway SA1 Cooling Fan Replacement: 步骤 7 中的图像 1,1
    • You are now able to remove the cooling fan.
结论
7等其他人完成本指南。
Diego Carteno
于04/15/10注册
273 声望
创作了7篇指南
团队
Cal Poly, Team 24-20, Regan Spring 2010 Cal Poly, Team 24-20, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G20
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 13,620
