这个步骤还没有翻译 帮忙翻译一下
Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the WiFi Card.
Make sure to unplug your laptop charger, as removing the WiFi while the device is charging may damage the WiFi and or the charger.
Gently pull the cover away from the device.
Remove the three wires above the WiFi Card.
Take note of the color for each wire and it's corresponding location.
Remove the two Phillips #0 (2mm) screws above the WiFi card.
The WiFi Card will lift up once the screws are removed.
With the WiFi Card lifted up, gently pull the WiFi Card out of the socket and remove it from the device.
取消:我没有完成这个指南。
与1其他贡献者
于03/19/18注册
507 声望
创作了4篇指南
徽章: 7
+ 4更多徽章
UMASSD-PEAK-S18S3G5
2 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 432
