当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn your laptop upside down and remove the four Philips #0 (5mm) screws for the cover of the hard drive.
Make sure to unplug your laptop charger, as removing the hard drive while the device is charging may damage the hard drive and or the charger.
Gently pull the cover away from the device.
Set the cover aside for now, until reassembly.
Pull the plastic tab as shown to remove the hard drive from the device.
Remove the four Philips #0 (3mm) screws around the case for the hard drive. There will be two screws and the left and right side.
Remove the hard drive from the case.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与2其他贡献者
于03/19/18注册
507 声望
创作了4篇指南
徽章: 7
+ 4更多徽章
UMASSD-PEAK-S18S3G5
2 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 303
