跳转到主内容
Gateway NV59C66u Battery Replacement
  1. Gateway NV59C66u Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
    • Locate the Latches below the battery.
  2. Gateway NV59C66u Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the vertical latch upward, unlocking the battery
  3. Gateway NV59C66u Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
  4. Gateway NV59C66u Battery Replacement: 步骤 4 中的图像 1,1
    • Now the battery is free. Proceed to lift and remove the battery.
    • Place the old batter to the side, as to not get it confused from your new battery you intend to install.
    • Take your new battery and position it into the battery slot you took the old one out of.
    • Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
    • Put latches in lock position and turn laptop over.
    • Turn on your computer.
结论
Jackson Gandee
于10/30/19注册
521 声望
创作了4篇指南
团队
ETECH Holdings ETECH Holdings 的会员
Community
2 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 12
总计 200
