跳转到主内容
Gateway NV55C49u Display Replacement
你所需要的
  1. Gateway NV55C49u Display Replacement, Display: 步骤 1 中的图像 1,1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Display Replacement: 步骤 2 中的图像 1,1
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u Display Replacement: 步骤 3 中的图像 1,2 Gateway NV55C49u Display Replacement: 步骤 3 中的图像 2,2
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u Display Replacement: 步骤 4 中的图像 1,1
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u Display Replacement: 步骤 5 中的图像 1,2 Gateway NV55C49u Display Replacement: 步骤 5 中的图像 2,2
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  6. Gateway NV55C49u Display Replacement: 步骤 6 中的图像 1,1
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u Display Replacement: 步骤 7 中的图像 1,1
    • Remove the two 6.0mm #00 Phillips screws from the area under the back cover.
  8. Gateway NV55C49u Display Replacement: 步骤 8 中的图像 1,1
    • Remove the nine 6.0mm #00 Phillips screws from the back of the laptop.
  9. Gateway NV55C49u Display Replacement: 步骤 9 中的图像 1,3 Gateway NV55C49u Display Replacement: 步骤 9 中的图像 2,3 Gateway NV55C49u Display Replacement: 步骤 9 中的图像 3,3
    • There are 6 small clips that holding the top row of the keyboard in place.
    • To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
    • Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
  10. Gateway NV55C49u Display Replacement: 步骤 10 中的图像 1,1
    • Once the keyboard is loose, slowly lift the keyboard away from the laptop.
    • There will be a single ribbon cable connecting the keyboard to the laptop body. Use two plastic opening tools to loosen the fastener,
    • After the fastener is loose, gently disconnect the cable.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much pressure.
  11. Gateway NV55C49u Display Replacement: 步骤 11 中的图像 1,3 Gateway NV55C49u Display Replacement: 步骤 11 中的图像 2,3 Gateway NV55C49u Display Replacement: 步骤 11 中的图像 3,3
    • Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much force.
    • Use a plastic pry tool to disconnect the single pinned connector.
  12. Gateway NV55C49u Display Replacement: 步骤 12 中的图像 1,1
    • Use a plastic opening tool to remove the disk drive cover on the right side of the laptop.
  13. Gateway NV55C49u Display Replacement: 步骤 13 中的图像 1,2 Gateway NV55C49u Display Replacement: 步骤 13 中的图像 2,2
    • Use the metal spudger to pry upwards on the disk drive until you can grab and remove it.
  14. Gateway NV55C49u Display Replacement: 步骤 14 中的图像 1,1
    • Now simply lift the face-plate off the laptop body.
    • This step exposes the motherboard, which is a sensitive part of the laptop. Make sure not to touch anything with your bare hands as a static shock could ruin the board.
  15. Gateway NV55C49u Display Replacement: 步骤 15 中的图像 1,1
    • Remove the ribbon wire that connects the display to the motherboard using two plastic opening tools.
  16. Gateway NV55C49u Display Replacement: 步骤 16 中的图像 1,2 Gateway NV55C49u Display Replacement: 步骤 16 中的图像 2,2
    • Remove the two 4.0mm #00 Phillips screws from both the top right and top left of the exposed laptop body.
    • The display is now fully disconnected.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 347
