跳转到主内容
Gateway NV55C49u Battery Replacement
你所需要的
  1. Gateway NV55C49u Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Battery Replacement: 步骤 2 中的图像 1,1
    • Switch the battery lock to show a red background with an unlock symbol
  3. Gateway NV55C49u Battery Replacement: 步骤 3 中的图像 1,2 Gateway NV55C49u Battery Replacement: 步骤 3 中的图像 2,2
    • Flip the switch with the battery symbol on it.
    • The battery should eject if done correctly.
  4. Gateway NV55C49u Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery by lifting the battery out.
  5. Gateway NV55C49u Battery Replacement: 步骤 5 中的图像 1,1
    • This battery contains harmful chemicals, so it must be disposed of properly. Please take the old battery to a waste disposal center or recycling center.
    • Tip: in France, you can dispose of the old battery in the battery disposal points that can be found in a lot of supermarkets.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 311
