跳转到主内容
Gateway NV53A24u Keyboard Replacement
你所需要的
  1. Gateway NV53A24u Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Before removing the keyboard, turn off the computer and open it.
  2. Gateway NV53A24u Keyboard Replacement: 步骤 2 中的图像 1,2 Gateway NV53A24u Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to gently pry out the keyboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
    • There are small metal tabs holding it in place beneath the bezel. Using your tool, you should be able to easily pop the keyboard out.
  3. Gateway NV53A24u Keyboard Replacement: 步骤 3 中的图像 1,2 Gateway NV53A24u Keyboard Replacement: 步骤 3 中的图像 2,2
    • Once the keyboard is removed, you may have to remove the connecting ribbon cable, but it easily pulls out.
结论
另外一个人完成了本指南。
tannerroan
于10/11/16注册
333 声望
创作了2篇指南
团队
USF Tampa, Team 1-5, Leahy Fall 2016 USF Tampa, Team 1-5, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 518
