简介
The battery pack will have to be taken out, so there can be access to the keyboard.
你所需要的
Turn the laptop on its backside with the stickers and barcode facing you.
Locate the latches on the top left corner.
Remove the five identical 9/32" Phillips Screws located under the battery and both upper corners using the Phillips #0 Screwdriver.
Flip the Device so the keyboard and display screen are faced upright.
Lift up the media button board cover using the Heavy Duty Spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
2等其他人完成本指南。
