跳转到主内容
Gateway NV52 Hard Drive Compartment Replacement
你所需要的
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: 步骤 2 中的图像 1,1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: 步骤 3 中的图像 1,1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: 步骤 4 中的图像 1,3 Gateway NV52 Hard Drive Compartment Replacement: 步骤 4 中的图像 2,3 Gateway NV52 Hard Drive Compartment Replacement: 步骤 4 中的图像 3,3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
结论
2等其他人完成本指南。
Tim En
于01/26/13注册
557 声望
创作了4篇指南
团队
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G24
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,000
