跳转到主内容
Gateway NE56R27u Screen Replacement
你所需要的
  1. Gateway NE56R27u Screen Replacement, Battery: 步骤 1 中的图像 1,2 Gateway NE56R27u Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Screen Replacement: 步骤 2 中的图像 1,2 Gateway NE56R27u Screen Replacement: 步骤 2 中的图像 2,2
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Screen Replacement, Screen: 步骤 3 中的图像 1,3 Gateway NE56R27u Screen Replacement, Screen: 步骤 3 中的图像 2,3 Gateway NE56R27u Screen Replacement, Screen: 步骤 3 中的图像 3,3
    • Using the spudger, remove the protective caps for the screen to expose the screws.
    • Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
  4. Gateway NE56R27u Screen Replacement: 步骤 4 中的图像 1,3 Gateway NE56R27u Screen Replacement: 步骤 4 中的图像 2,3 Gateway NE56R27u Screen Replacement: 步骤 4 中的图像 3,3
    • Using the opening pick in between the front cover and bezel, gently loosen and lift the plastic bezel from the screen and backing.
  5. Gateway NE56R27u Screen Replacement: 步骤 5 中的图像 1,2 Gateway NE56R27u Screen Replacement: 步骤 5 中的图像 2,2
    • Gently lift the frame of the screen from the top to unhook the frame from the base.
    • When reassembling, hook the bottom of the screen to the base of the laptop before snapping into place.
  6. Gateway NE56R27u Screen Replacement: 步骤 6 中的图像 1,3 Gateway NE56R27u Screen Replacement: 步骤 6 中的图像 2,3 Gateway NE56R27u Screen Replacement: 步骤 6 中的图像 3,3
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws in the front corners of the metal frame.
    • Lift the screen slightly to expose the connector board.
  7. Gateway NE56R27u Screen Replacement: 步骤 7 中的图像 1,2 Gateway NE56R27u Screen Replacement: 步骤 7 中的图像 2,2
    • Using the spudger, carefully remove the webcam connector from the metal frame.
  8. Gateway NE56R27u Screen Replacement: 步骤 8 中的图像 1,2 Gateway NE56R27u Screen Replacement: 步骤 8 中的图像 2,2
    • Peel the tape covering the display cable, releasing the wire from the metal frame.
    • Unplug the display cable from the image processing board on the screen.
  9. Gateway NE56R27u Screen Replacement: 步骤 9 中的图像 1,2 Gateway NE56R27u Screen Replacement: 步骤 9 中的图像 2,2
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws from the sides of the metal frame.
    • Remove the screen from the metal frame.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 213
