跳转到主内容
Gateway NE56R27u Motherboard Replacement
你所需要的
  1. Gateway NE56R27u Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Gateway NE56R27u Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Motherboard Replacement: 步骤 2 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 2 中的图像 2,2
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Motherboard Replacement, Hard Drive: 步骤 3 中的图像 1,3 Gateway NE56R27u Motherboard Replacement, Hard Drive: 步骤 3 中的图像 2,3 Gateway NE56R27u Motherboard Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
  4. Gateway NE56R27u Motherboard Replacement: 步骤 4 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the opening tool to gently pry open the compartment covering.
  5. Gateway NE56R27u Motherboard Replacement: 步骤 5 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 5 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 5 中的图像 3,3
    • Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
    • Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
    • The hard drive plugs into the port on the left within the compartment. Be sure to gently remove the hard drive without damaging the port.
  6. Gateway NE56R27u Motherboard Replacement: 步骤 6 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
  7. Gateway NE56R27u Motherboard Replacement, Keyboard: 步骤 7 中的图像 1,2 Gateway NE56R27u Motherboard Replacement, Keyboard: 步骤 7 中的图像 2,2
    • Flip your laptop over to view the keyboard.
    • Using the spudger, push in the ten tabs at the edges of the keyboard.
  8. Gateway NE56R27u Motherboard Replacement: 步骤 8 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using the opening pick, lift the edges of the keyboard.
    • Repeat around the edges of the device.
    • Lift up the keyboard to expose the cables underneath.
  9. Gateway NE56R27u Motherboard Replacement: 步骤 9 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 9 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 9 中的图像 3,3
    • Release the clamp holding the mini-DIN cord by lifting the two black tabs on either side.
    • Gently pull the mini-DIN cord out of the clamp.
    • Remove the keyboard.
  10. Gateway NE56R27u Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,2 Gateway NE56R27u Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,2
    • Using a Phillips #000 driver, remove the three silver 0.79mm screws located on the back edge of the battery compartment.
  11. Gateway NE56R27u Motherboard Replacement: 步骤 11 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 11 中的图像 2,2
    • Using a Phillips #000 driver, remove all nineteen of the remaining 0.79mm screws that are holding the back case in place.
  12. Gateway NE56R27u Motherboard Replacement: 步骤 12 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 12 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 12 中的图像 3,3
    • Using the flat end of the spudger, slide the optical drive out.
  13. Gateway NE56R27u Motherboard Replacement: 步骤 13 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 13 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 13 中的图像 3,3
    • Using the hook end of a halberd spudger, gently pry up the black and white wires from the wireless card.
  14. Gateway NE56R27u Motherboard Replacement: 步骤 14 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 14 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 14 中的图像 3,3
    • Using the flat side of the spudger, pry the wireless card out of its slot.
    • The card will then pop upwards at a 45 degree angle. At this point, gently pull the card out.
  15. Gateway NE56R27u Motherboard Replacement: 步骤 15 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 15 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 15 中的图像 3,3
    • Flip the laptop back over.
    • Once the keyboard is removed, use the pointed-end of the spudger to release the touch pad cable.
    • Gently slide both sides of the clip upward towards the screen in order to release the cable.
  16. Gateway NE56R27u Motherboard Replacement: 步骤 16 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 16 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 16 中的图像 3,3
    • Using the spudger, gently slide the clamp holding the MS cable upward towards the screen. Carefully remove the cable from its housing.
  17. Gateway NE56R27u Motherboard Replacement: 步骤 17 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 17 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 17 中的图像 3,3
    • Using the opening pick, carefully pry the palm rest assembly upwards.
    • Work the pick around the perimeter until all of the clips are released.
  18. Gateway NE56R27u Motherboard Replacement: 步骤 18 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 18 中的图像 2,2
    • Gently life the side closest to you up towards the screen.
  19. Gateway NE56R27u Motherboard Replacement: 步骤 19 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 19 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 19 中的图像 3,3
    • Using the plastic spudger, release the cable from the ZIF connectors and remove all four ribbon cables on the motherboard.
  20. Gateway NE56R27u Motherboard Replacement: 步骤 20 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 20 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 20 中的图像 3,3
    • Remove the tape holding the white wire and gently pull it out of its hole.
  21. Gateway NE56R27u Motherboard Replacement: 步骤 21 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 21 中的图像 2,2
    • Use the Phillips #000 driver to remove the two remaining 3mm silver screws.
  22. Gateway NE56R27u Motherboard Replacement: 步骤 22 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 22 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 22 中的图像 3,3
    • Use the spudger to slide the SD card out of the back left corner of the system board.
  23. Gateway NE56R27u Motherboard Replacement: 步骤 23 中的图像 1,2 Gateway NE56R27u Motherboard Replacement: 步骤 23 中的图像 2,2
    • Gently lift the motherboard towards the screen.
    • Avoid contact with the connecting cable. Force will cause damage to the cable.
  24. Gateway NE56R27u Motherboard Replacement: 步骤 24 中的图像 1,3 Gateway NE56R27u Motherboard Replacement: 步骤 24 中的图像 2,3 Gateway NE56R27u Motherboard Replacement: 步骤 24 中的图像 3,3
    • Use the spudger to disconnect the last cable holding the motherboard to the system board.
    • Lift the motherboard straight up, being careful not to damage the fan or other sensitive parts.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 612
