跳转到主内容
Gateway NE56R27u Keyboard Replacement
你所需要的
  1. Gateway NE56R27u Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Gateway NE56R27u Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Keyboard Replacement: 步骤 2 中的图像 1,2 Gateway NE56R27u Keyboard Replacement: 步骤 2 中的图像 2,2
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Keyboard Replacement, Hard Drive: 步骤 3 中的图像 1,3 Gateway NE56R27u Keyboard Replacement, Hard Drive: 步骤 3 中的图像 2,3 Gateway NE56R27u Keyboard Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
  4. Gateway NE56R27u Keyboard Replacement: 步骤 4 中的图像 1,2 Gateway NE56R27u Keyboard Replacement: 步骤 4 中的图像 2,2
    • Use the opening tool to gently pry open the compartment covering.
  5. Gateway NE56R27u Keyboard Replacement: 步骤 5 中的图像 1,3 Gateway NE56R27u Keyboard Replacement: 步骤 5 中的图像 2,3 Gateway NE56R27u Keyboard Replacement: 步骤 5 中的图像 3,3
    • Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
    • Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
    • The hard drive plugs into the port on the left within the compartment. Be sure to gently remove the hard drive without damaging the port.
  6. Gateway NE56R27u Keyboard Replacement: 步骤 6 中的图像 1,2 Gateway NE56R27u Keyboard Replacement: 步骤 6 中的图像 2,2
    • Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
  7. Gateway NE56R27u Keyboard Replacement, Keyboard: 步骤 7 中的图像 1,2 Gateway NE56R27u Keyboard Replacement, Keyboard: 步骤 7 中的图像 2,2
    • Flip your laptop over to view the keyboard.
    • Using the spudger, push in the ten tabs at the edges of the keyboard.
  8. Gateway NE56R27u Keyboard Replacement: 步骤 8 中的图像 1,2 Gateway NE56R27u Keyboard Replacement: 步骤 8 中的图像 2,2
    • Using the opening pick, lift the edges of the keyboard.
    • Repeat around the edges of the device.
    • Lift up the keyboard to expose the cables underneath.
  9. Gateway NE56R27u Keyboard Replacement: 步骤 9 中的图像 1,3 Gateway NE56R27u Keyboard Replacement: 步骤 9 中的图像 2,3 Gateway NE56R27u Keyboard Replacement: 步骤 9 中的图像 3,3
    • Release the clamp holding the mini-DIN cord by lifting the two black tabs on either side.
    • Gently pull the mini-DIN cord out of the clamp.
    • Remove the keyboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 21
总计 586
