简介
Removing the upper case of the laptop is necessary if the case is significantly damaged since it is essentially to protecting the laptop's internal components. Upper case removal is also a necessary preliminary step for replacing many of these internal components. Remove battery before upper cover case.
你所需要的
After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
即将完成!
结论
