跳转到主内容
Gateway NE52203u USB Port Replacement
你所需要的
  1. Gateway NE52203u USB Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over onto its backside in order to access the battery.
  2. Gateway NE52203u USB Port Replacement: 步骤 2 中的图像 1,2 Gateway NE52203u USB Port Replacement: 步骤 2 中的图像 2,2
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
  3. Gateway NE52203u USB Port Replacement: 步骤 3 中的图像 1,1
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
  4. Gateway NE52203u USB Port Replacement, Touchpad Assembly: 步骤 4 中的图像 1,2 Gateway NE52203u USB Port Replacement, Touchpad Assembly: 步骤 4 中的图像 2,2
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  5. Gateway NE52203u USB Port Replacement: 步骤 5 中的图像 1,1
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  6. Gateway NE52203u USB Port Replacement: 步骤 6 中的图像 1,2 Gateway NE52203u USB Port Replacement: 步骤 6 中的图像 2,2
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  7. Gateway NE52203u USB Port Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  8. Gateway NE52203u USB Port Replacement: 步骤 8 中的图像 1,3 Gateway NE52203u USB Port Replacement: 步骤 8 中的图像 2,3 Gateway NE52203u USB Port Replacement: 步骤 8 中的图像 3,3
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
  9. Gateway NE52203u USB Port Replacement, USB Port: 步骤 9 中的图像 1,2 Gateway NE52203u USB Port Replacement, USB Port: 步骤 9 中的图像 2,2
    • Using a spudger, pry the ZIF connector upwards.
  10. Gateway NE52203u USB Port Replacement: 步骤 10 中的图像 1,1
    • Use your fingers to gently disconnect the ribbon wire from the USB circuit board.
  11. Gateway NE52203u USB Port Replacement: 步骤 11 中的图像 1,1
    • Using a #00 Phillips head screwdriver, remove the 2.9 mm screw on the USB circuit board.
  12. Gateway NE52203u USB Port Replacement: 步骤 12 中的图像 1,1
    • Finally, remove the old USB port.
结论
3等其他人完成本指南。
Stephen Spees
于03/20/15注册
542 声望
创作了4篇指南
团队
Baylor, Team 2-1, Grigsby Spring 2015 Baylor, Team 2-1, Grigsby Spring 2015 的会员
BU-GRIGSBY-S15S2G1
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 780
