跳转到主内容
Gateway NE51006u Hard Drive Replacement
你所需要的
  1. Gateway NE51006u Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Ensure device is powered off and unplugged from a power source. Place the device upside down.
  2. Gateway NE51006u Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use a PH0 Phillips head screwdriver to remove the 9.0 mm screw on the rectangular panel underneath the device.
  3. Gateway NE51006u Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to pry open the rectangular panel the 9.0 mm screw was removed from.
  4. Gateway NE51006u Hard Drive Replacement: 步骤 4 中的图像 1,3 Gateway NE51006u Hard Drive Replacement: 步骤 4 中的图像 2,3 Gateway NE51006u Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Remove a single 9.0 mm screw on the silver box containing the hard drive. Pull the plastic flap at the side opposite to the side of the screw housing back in order to remove the silver box containing the hard drive.
  5. Gateway NE51006u Hard Drive Replacement: 步骤 5 中的图像 1,3 Gateway NE51006u Hard Drive Replacement: 步骤 5 中的图像 2,3 Gateway NE51006u Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Remove the two 9.0 mm screws on each side of the silver box to slide the hard drive from the silver box housing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 308
