跳转到主内容
Gateway MS2370 Screen Replacement
你所需要的
  1. Gateway MS2370 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Screen Replacement: 步骤 2 中的图像 1,1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Screen Replacement, Screen: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the pointed tweezers, remove plastic circles that are stuck onto the back of the laptop’s hinges.
    • These plastic circles are stuck inside the hole with adhesive and might require a significant amount of force.
  5. Gateway MS2370 Screen Replacement: 步骤 5 中的图像 1,2 Gateway MS2370 Screen Replacement: 步骤 5 中的图像 2,2
    • Unscrew both of the 3mm Phillips 01 screws on both hinges using the matching screwdriver.
  6. Gateway MS2370 Screen Replacement: 步骤 6 中的图像 1,1
    • Take the plastic spudger and pull up the tabs on all four sides of the screen molding.
  7. Gateway MS2370 Screen Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the screen molding. Be aware that the screen molding will not come out all the way.
  8. Gateway MS2370 Screen Replacement: 步骤 8 中的图像 1,1
    • Unscrew the four 3mm inch Phillips 01 screws on the screen bracket.
  9. Gateway MS2370 Screen Replacement: 步骤 9 中的图像 1,3 Gateway MS2370 Screen Replacement: 步骤 9 中的图像 2,3 Gateway MS2370 Screen Replacement: 步骤 9 中的图像 3,3
    • Peel up the tape over the connector and unplug the screen from the laptop.
  10. Gateway MS2370 Screen Replacement: 步骤 10 中的图像 1,2 Gateway MS2370 Screen Replacement: 步骤 10 中的图像 2,2
    • Slowly remove the screen from the laptop.
结论
团队
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 804
