跳转到主内容
加入维修社区 - 创建账户
Gateway MS2370 RAM Replacement
你所需要的
  1. Gateway MS2370 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 RAM Replacement: 步骤 2 中的图像 1,1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 RAM Replacement: 步骤 3 中的图像 1,1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Unscrew the three 10mm inch Phillips 01 screws on the back of your laptop.
    • Unplug everything from the USB and SD ports.
  5. Gateway MS2370 RAM Replacement: 步骤 5 中的图像 1,1
    • Remove the cover panel.
    • This exposes more screws that must be removed.
  6. Gateway MS2370 RAM Replacement: 步骤 6 中的图像 1,1
    • Unplug the two exposed cables from the motherboard.
  7. Gateway MS2370 RAM Replacement: 步骤 7 中的图像 1,2 Gateway MS2370 RAM Replacement: 步骤 7 中的图像 2,2
    • Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
    • This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
  8. Gateway MS2370 RAM Replacement: 步骤 8 中的图像 1,2 Gateway MS2370 RAM Replacement: 步骤 8 中的图像 2,2
    • Pry the laptop case apart.
    • The disc drive in this photo was removed. You can remove it just by puling it out when the previous step is completed.
  9. Gateway MS2370 RAM Replacement: 步骤 9 中的图像 1,1
    • Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
    • This cable has a special connector the requires you to lift open a grey flap to unplug properly.
    • The keyboard plug is located at the center of the motherboard and can be unplugged like a normal cable.
  10. Gateway MS2370 RAM Replacement: 步骤 10 中的图像 1,1
    • Remove the top half of the case.
  11. Gateway MS2370 RAM Replacement: 步骤 11 中的图像 1,1
    • Unscrew all 5 10mm inch Phillips 01 screws.
    • One more off screen
  12. Gateway MS2370 RAM Replacement: 步骤 12 中的图像 1,3 Gateway MS2370 RAM Replacement: 步骤 12 中的图像 2,3 Gateway MS2370 RAM Replacement: 步骤 12 中的图像 3,3
    • Unplug the ribbon cable connected to the USB Hub, the network card, and the monitor cable.
  13. Gateway MS2370 RAM Replacement: 步骤 13 中的图像 1,1
    • Flip the motherboard over.
  14. Gateway MS2370 RAM Replacement: 步骤 14 中的图像 1,3 Gateway MS2370 RAM Replacement: 步骤 14 中的图像 2,3 Gateway MS2370 RAM Replacement: 步骤 14 中的图像 3,3
    • Using your two thumbs to pull outwards from the inside of the RAM slot to release and remove the RAM.
    • The last step of this replacement guide is not required to complete the fan replacement guide.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 1,814
